Lockdown Specials
Join HiFiMART Telegram Channel for offers & deals
HiFiVision
Super Moderator
We will be introducing a series of Lockdown Special offers and deals. Please visit this thread for updates on new offers and deals.
As usual, all offers and deals come with:
  • ✓ FREE Shipping to most locations in India
  • ✓ Official Manufacturers Warranty valid in India
  • ✓ Brand NEW in Box & 100% Original
  • ✓ Authorised Online Dealer
  • ✓ Price includes GST
  • ✓ Electronic products run on 230 volts
  • ✓ EMI payment option available
  • ✓ Safe and Secure Checkout
Please note:
  • Offers are good for a limited time only and/or till stocks last.
  • Offers can be withdrawn at any time without prior notice.
  • All HiFiMART Coupon codes can be used with the deals.
HiFiVision
Super Moderator
Marantz PM7000N Plus Mission LX-2 Speakers
Purchase the Marantz PM7000N with the Mission LX-2 speakers for a very special offer price.
Marantz PM7000N
The Marantz PM7000N is the first Marantz Current Feedback integrated Hi-Fi amplifier with HEOS Built-in technology. The ideal choice for audio connoisseurs, the PM7000N includes high-grade audio components, Marantz own HDAMs, a toroidal transformer and a high-speed instantaneous current power supply. Stream your favourite music and enjoy high-resolution digital audio files up to 192kHz/24bit or DSD5.6. Switch to the high-quality Phono MM input to listen to your beloved vinyl as never before. The digital inputs support PCM audio and decode – besides MP3 – lossless digital files like ALAC, FLAC and WAV up to 24-bit/192-kHz for high-resolution listening. USB-A and HEOS Built-in additionally support DSD 2.8MHz and 5.6MHz playback. Stream your favourite music wirelessly via AirPlay2 and Bluetooth, and control the amplifier via the HEOS app or with leading voice agents Apple Siri, Google Assistant and Amazon Alexa where supported.
Mission LX-2 Speakers (Pair)
The Mission LX-2 Bookshelf Speaker (PAIR) utilises Mission’s traditional driver configuration and placing the tweeter below the mid/bass, the Mission LX-2 Speakers have been constructed with Mission’s roots at the forefront of the design team’s minds. The traditional arrangement facilitates times alignment between drivers for better synchronisation of sound production from each speaker as it reaches the listener. The LX-2 uses a 25mm microfibre dome tweeter and a 13cm fibre composite mid and bass driver through a 4th order design single-wire crossover. Due to the care in which the drives have been developed, the Mission LX-2 Speakers deliver low distortion and an even response.
HiFiVision
Super Moderator
Marantz PM8006 Integrated Amplifier
The Marantz PM8006 Integrated Amplifier comes with a fully discrete current feedback design, the PM8006 integrated amplifier is perfect for audiophiles wanting both excellent music quality and flexible operation. It offers a powerful 2x 70W into 8 ohm, while the symmetrical circuits ensure optimal imaging. To ensure the most involving musical experience, the amplifier uses a new Marantz-designed electric volume control and brand-new Marantz Musical Phono EQ phono preamp stage, designed to get the purest signal from beloved vinyl by minimized noise levels. To further remove interference, new isolating feet are used to support the amplifier, combining high density and a damping fibre.
The Marantz PM8006 also includes preamp outputs along with a power amp direct input, which lets you use the unit as a standalone power amplifier for integration into a multi-channel home theatre system. For precise sound tailoring, our triple tone control system provides separate controls for the bass, midrange and treble. The elegant remote control features an ergonomic layout for easy operation and can control accompanying source players.
Key Features of Marantz PM8006 Integrated Amplifier
  • Integrated Current Feedback Amplifier with 2x 70W / 8 Ω rms
  • Newly designed electric volume circuit
  • Exceptional Marantz Musical Phono EQ stage
  • Marantz proprietary HDAM-SA3 circuits
  • Triple-layer bottom plate
  • Gold Plated Inputs/Outputs incl. Phono (MM) input
  • Double shielded Toroidal Transformer and high quality customized components
  • High quality, original Marantz SPKT-1+ Speaker Terminals (A / B switchable)
Current Feedback
Current Feedback amplification is a well-known, Marantz-original circuit technology, suiting perfectly with the requirements of Super Audio hi-res music for wide-bandwidth, high-speed reproduction. The impedance at the Current Feedback point is limited resulting in a very low phase shift, meaning Marantz Current Feedback amplifiers reduce the need for phase compensation via Negative FeedBack (NFB) to a minimum. This simplified the signal path, resulting in high through-rate, excellent transient response and superb sonic transparency across the full bandwidth. Unlike conventional Voltage Feedback topology, Current Feedback also makes the power amplifier insensitive to difficult loudspeaker loads.
Marantz HDAM Technology
Marantz developed its own discrete circuit boards, called Hyper-Dynamic Amplifier Modules, or HDAMs, to replace the chip-based amps used elsewhere. Using discrete surface mount components with short mirror-image left and right signal paths, HDAMs outperform the regular integrated Op-amps dramatically in Slew Rate and noise level, resulting in a much more dynamic, accurate and detailed sound. Over the years Marantz has developed different HDAMs to fit the particular requirements of players and amplifiers: the Marantz PM8006 uses the high-grade SA3 version.
For a long time, Marantz integrated amplifiers have featured high-quality phono stages, but now the company takes its commitment to vinyl to new levels with the Marantz Musical Phono EQ stage, launched in the Marantz PM8006 amplifier. This unique technology, simplifying the signal path in the phono stage for optimal sound quality, underlines the company’s commitment to the very best playback of all music sources, be they digital or analogue. Marantz Musical Phono EQ uses two-stage amplification, allowing less gain per stage, for lower distortion. Of course, being a Marantz design it uses the company’s HDAMs, but here they’re combined with JFETs (junction gate field-effect transistors) in the input stage, giving a high input impedance. This allows the deletion of the AC coupling capacitors previously used providing a simpler signal path for the tiny output from a phono cartridge, improving signal purity.
Marantz has also rethought the re-equalization process within the phono stage, a fundamental part of vinyl replay required to compensate for the limitations of the format. In the Marantz Musical Phono EQ stage, this re-equalization is split into passive and active sections, for more accurate equalisation: the RIAA correction is carried out within an HDAM, while amplification is in the hands of a high-quality op-amp, running in Class A mode for minimal distortion, and delivering a clean and open sound. With Marantz Musical Phono EQ there’s no need to consider upgrading the Marantz PM8006 with offboard phono stage: as part of Marantz’s commitment to optimising playback of all format, be they digital or analogue, the amplifier already has premium-class phono capability built-in.
A Toroidal transformer has several advantages over a normal EI core transformer. It is very efficient and therefore delivers more power compared to the same size as an EI core transformer. In addition, due to its shape, the electromagnetic radiation and the mechanical vibration are extremely low all ending in better sound quality.
Often under-estimated: a high-quality volume control
A newly developed electric volume control using the latest volume control IC realizes better channel separation, dynamic range and distortion-reduction while retaining the operational feel of an analogue volume control device. To ensure the most involving musical experience, the amplifier uses a new Marantz-designed electric volume control for high linearity and best-in-class channel separation.
The terminals are made of massive brass with a thick silver plating for the best possible contact with the speaker cables, and the main speaker terminals are mounted lower, and thus closer to the main circuit board, to reduce the signal path. That’s in keeping with the entire design of the amplifier, which uses the shortest possible signal paths and High Instantaneous Current topology for better speed and dynamics.
Specification of the Marantz PM8006 Integrated Amplifier
  • Power Output (8 / 4 Ohm RMS) 70 W / 100 W
  • Frequency Response 5 Hz-100 kHz
  • Total Harmonic Distortion 0.02 %
  • Damping Factor 100
  • Input Sensitivity: MM 2 mV / 47 kOhm
  • Signal to Noise Ratio: MM / MC 87 dB / –
  • Input Sensitivity: High level 200 mV / 20 kOhm
  • Input Sensitivity: Balanced High level –
  • Signal to Noise Ratio: High level 106dB(2V input)
  • Input Sensitivity: Power Amp Direct IN 1.6V / 15 kOhm
  • Signal to Noise Ratio: Power Amp Direct IN 125 dB
HiFiVision
Super Moderator
Marantz MODEL 30 Integrated Amplifier
Get the most musical sound possible from this beautiful, Marantz MODEL 30 Integrated Amplifier. Exquisitely tuned by the Marantz Sound Master, the MODEL 30 integrated amplifier features a master-curated Marantz HDAM and a fully discrete design for luxurious Hi-Fi purity. Designed to last the test of time and make all your music unforgettable.
Featuring a fully discrete, two-stage design for minimal interference, and unique Marantz HDAM technology for signal purity, MODEL 30 offers exceptional sound quality.
Tuned with passion
Hundreds of hours of thoughtful Sound Master tuning ensure the exquisite detail and musicality Marantz always delivers.
Designed to last
You see and feel it in the build quality and you hear it every time. No matter your musical passions, your music always sounds better with MODEL 30.
Fully discrete and accurate detailing
Marantz HDAM-SA3 technology is comprised of dozens of independent parts, each hand-selected for pure, detailed Marantz sound.
Extraordinary sensitivity
Designed to replicate the sensitivity and feel of a vintage analogue amplifier even when simply adjusting the volume.
Exquisite sound tuning
Marantz MODEL 30 Integrated Amplifier continues the renowned heritage of exquisite Marantz amplifiers. Tuned by the Marantz Sound Master who channelled his passion, experience, and extraordinary ear into the amplifier design.
The most musical, accurate, detailed sound
Marantz MODEL 30 Integrated Amplifier is built on its own discrete circuit board, the Hyper-Dynamic Amplifier Module, or HDAM.
Marantz Musical Premium Phono EQ
Envisioned to deliver optimal sound quality by simplifying the signal path – vital given the delicate nature of phono signals – the Phono EQ stage in MODEL 30 can be used with both moving magnet and low-output moving coil cartridges, thanks to a built-in MC head amplifier.
MC / MM phono input impedance selector
In order to optimize sound performance when using a moving coil (MC) or magnetic moving (MM) cartridge, and to accommodate all configurations as much as possible, MODEL 30 is equipped with an input impedance selector.
Built for Generations
Like its counterpart, the SACD 30n Streaming CD Player, the MODEL 30 Integrated Amplifier is designed to the highest standards.
More Than 65 Years of Audiophile Heritage
Founded in 1953, Marantz has a long and rich history of designing audio components embraced by music lovers and critical listeners around the world.
Features of the Marantz MODEL 30 Integrated Amplifier
  • Independent pre-amplifier and power amplifier section.
  • Toroidal transformer feed power supply dedicated to pre-amplifier.
  • Current feedback pre-amplifier design for clarity and details.
  • Marantz HDAM technology for low noise and extended frequency range.
  • Linear volume control with new electric volume system for best linearity.
  • Switching mode power amplifier with a dedicated SMPS power supply.
  • Solid output of 100W + 100W (8ohm), 200W + 200W (4ohm) to drive any speaker.
  • Amplifier design inherited from our flagship models.
  • Flat frequency response independent to the connected speaker load.
  • MM/MC Phono input with selectable MC input resistance.
  • Extra high quality, low resistant input terminals for CD and Phono.
  • Marantz original high-quality/high-purity copper speaker terminals.
