Looking for Golden Field GD010 2.1 Multimedia Speaker
rishiguru
In the Haze..
Hi, I am looking for this Golden Field GD010 2.1 Multimedia Speaker in India. I reside in Kolkata. If anybody have any contacts to a dealer in India who can provide me this set i will be very thankful.
Golden Field GD010
Golden Field is a Chinese company. But this set in has stellar specification & good quality of construction.
Product webpage: Golden Field GD010
Specifications
Total Continuous Power(RMS): 150W
Total Peak Power(RMS): 300W
Satellite Output Power(RMS): 25W 2 (fo = 1KHz, THD = 10%)
Subwoofer Output Power(RMS): 100W (fo = 50Hz, THD = 10%)
THD: <0.5% (1KHz, 1W)
Overall frequency response of power amplifier:
The satellites) channels: 100Hz-20KHz ( 3dB)
Subwoofer channel: 30Hz-100Hz ( 3dB)
Input Interface: ?3.5 stereo plug line input, RCA input
Left and right channel frequency response deviation: <3dB
SNR: ? 80dB
Separation: ? 45dB
Line input impedance: 10Kohm
Main features: volume control, treble bass adjustment, remote control
Bass Driver: 8 inches (8? 100W)
Midrange Driver: 4 inch (8? 25W)
Tweeter: 1 inch (12? 20W)
Input voltage: 220V/50Hz 300W
Low Speaker Size: 280 (L) 350 (W) 325 (D) mm
The satellites Size: 158 (L) 265 (W) 168 (D) mm
Package Size: 419 (L) 375 (W) 581 (D) mm
Weight: total weight of about 16.8 Kg
Executive Standard: Q/JHT2
GD010 accepts USB devices and reads SD cards & plays MP3 songs directly from them.
Multifunctional Infrared Remote
Separate Controls in Subwoofer
Satellites have separate 4 inch midrange & 1 inch silk dome tweeter
Midrange Driver
Tweeter
Bass Driver
Uses Toroidal transformer instead of cheaper EI type
Amplifier
OP Amp Circuit Board
Power Amplifier Circuit Board
Amplifier of GD010 uses two high qualitative STMicroelectronics power amplifiers.
i) One STMicroelectronics TDA7294 Class-AB 100W amplifier powering the subwoofer.
2) One STMicroelectronics TDA7292 Class-AB 80W[40W + 40W] amplifier powering the two satellites.
3)Four filter capacitors reaching near 20,000uF value.
4) One STMicroelectronics TDA7313, this chip is used to handle the remote control to issue commands.
I know, this set may be not a match for my Logitech Z-2300 200W RMS THX certified system, still i was thinking of buying this one and connect to my other PC. Please anyone???
