Luxman L-505uxMkII Integrated Amplifier for ₹3,05,900
HiFiVision
Super Moderator
The L-505uXII is the eagerly awaited Mark II version of the popular L-505uX that has been at the forefront of pre-amplifier design since it's launch in 2011. Incorporating an abundance of proprietary technologies, such as Luxman's Version 4.0 ODNF (Only Distortion Negative Feedback), as well as LECUA (Luxman Electronically Controlled Ultimate Attenuator), this product is a truly multifunctional integrated amplifier. As Luxman's latest high-end model, the L-505uXII continues the evolution of the L-505 series, which has attracted many fans of audio quality and earned a great reputation. As an amplifier which exudes sophistication and authenticity beyond its class, the L-505uXII represents the latest in a long line of exemplary models.
Specification of Luxman L-505uXII Integrated Amplifier
Rated output 100W + 100W (8Ω), 150W + 150W (4Ω)
Input sensitivity/input impedance
PHONO (MM): 2.5mV/47kΩ PHONO (MC): 0.3mV/100Ω
LINE: 180mV/47kΩ
BAL.LINE: 180mV/55kΩ
MAIN-IN: 1V/47kΩ
Output voltage REC OUT: 180mV, PRE-OUT: 1V
Frequency response
PHONO: 20Hz to 20kHz (within -3dB)
LINE: 20Hz to 100kHz (within -3dB)
Total harmonic distortion
0.009% or less (8Ω, 1kHz)
0.09% or less (8Ω, 20Hz to 20kHz)
S/N ratio (IHF-A)
PHONO (MM): 91dB or more
PHONO (MC): 75dB or more
LINE: 104dB or more
Volume adjustment LECUA
Amplification circuit ODNF 4.0
Output configuration Bipolar parallel push-pull
Damping factor 210
Max. amount of tone control BASS: ±8dB at 100Hz, TREBLE: ±8dB at 10kHz
Power supply 230V~(50Hz) / 115V~(60Hz)
Power consumption 270W, 85W (under no signal), 0.4W (at standby)
External dimensions 440(W) x 178(H) x 454(D) mm
Net weight 22.5kg (main unit)
Accessories Remote control (RA-17A), Power cable
Order the Luxman L-505uxMkII Integrated Amplifier for ₹3,05,900
SPONSORED ADS
SPONSORED ADS
kvandhi
Chennai
Just curious to know , Why this amp price is so expensive, Is it Tube/Hybrid amplifier.
pravine
Chennai
;) Luxman is the the father of Accuphase
True... Luxman 505 Ux MKII Integrated amp will handle any speaker easly..... just wondering how good will be Luxman 509... I can't imagine the level of high quality output...
SPONSORED ADS
