m-Audio AV42 how to connect to MacBook Pro ?
If you have a usb sound card then connect sound card to Mac pro and LR cable from sound card to speakers. If you dont have card then connect headphone out from Mac pro to speakers using audio cable which has one end as 3.5mm jack and at the other end LR connecters.
Hope this helps.
Hope this helps.
Confusing. Actually I don't see any 3.5 port in the both the boxes
