Marantz 7015
Zakoro
Middelburg
I have a Marantz 7015 with 1 subwoofer and would like to add the 2nd one but on the settings the 2nd subwoofer is grey and can't be edited.
Please help
Once the second sub is connected it will be enabled. Check the wires / connection are intact.
If it's not enabled still, Try running the setup again after connecting the second sub.
Please help
You need to go to speaker configuration and change subwoofer from 1 to 2
Run Audyssey again and choose subwoofer as 2 during the initial speaker configuration setup, you anyways would need to run Audyssey to have the right curve applied after adding the second sub.
