sir,
can i bi amp my marantz sr 5006 to heco floor standing speakers
Yes.. it is possible... If your speakers have Bi-amp termials, you need to remove the clip (or) Jumper between the termials first....
Connect the Left & Right output of the AVR to the LF of the towers....
Connect the Surround back left & right channel output of the AVR to the HF terminals of the towers....
But before that you need to change the speaker setting in your AVR as Bi-amp....
I have done this on my Onkyo TX NR 818 AVR and been using it for close to 7 months time...
Hi elangoas
Nice to see that you have done some experimentation with bi-amping. So can you share some more details on the overall improvement in SQ with bi-amping ? I have seen some dismissing the importance of bi-amping (i.e passive bi-amping) and I also read some reviews of some AV receivers which were claimed to perform better with bi-amping. You have been with bi-amping for 7 months and it means you must have seen a better performance. Please throw some more light on your experiment.
Thanks Elangos. Even I did with AVRs surround but I didnt see a big difference.
Probably I might have not checked the difference immediately, with and without biamping.I will do it once more and check with an A to B comparison.
Can you tell me how you did biamping using AVR and stereo power amplifier?
Renjith
Hi Renjith,
Which AVR did you use for bimaping your speakers ? Could you please tell how did you do the bi-amping with your FS....
For doing bi-amping with AVR + stereo amplifier, your AVR should have Pre-outs for L & R channels..... Connect the AVR's preout L & R channels to stereo power amplifiers L & R in.....Once you have connected, connected the LF driver of the Floor standers to it....
Connect the HF of the towers to the AVR's L & R output directly....
Hope i am clear....Let me know if wasn't clear anywhere...
Hi Elangos,
I have NAD T757 and it has preout.
You are using stereo amp as a power amp.I got your point.
Renjith
You are telling about speaker jumper?
Speaker has for sure.
