slimetcake
Hello :licklips:
I've searched the forum for a while without having found a precise answer for my question, so here it goes.
Having finally bought some speakers, which are the XTZ 93.23s I've noticed that the 6.5" cones have a tendency to extend pretty far in and out when playing at loud volumes.
I would say that from their resting point they travel about 5mm on loud bass notes.
While XTZ says that the cones are very durable, I'm still worried if I might break them from over excursion.
My question is if any of you guys have any knowledge about the normal maximum excursion (xmax) for speakers with 6.5" woofers?
Am I fine as long as I don't hear any distortion from the speakers?
Also, have you ever broken a speaker as a result of over excursion, and if yes, how far did the cone extend?
