Music System Unit for Innova GX
huntersingh
knp
Hello,
just got the Innova GX (so no base music system, just the 4 regular speakers which came with the car)
Please advie best things which can be done to get the best music experience out of this
Budget : 20K
(incase i need to remove the current speakers, im open to do so also )
you can try JBL tube subwoofer..JBL mono block amp for this..and a main system sony/pioneer and an JBL amp...
keep the 4 speakers as of now..
later upgrade that..
try shopclues and e bay..
there are many options..within that budget..
So i realized i had to extend my budget to 30k
So now choices are as belows
HU : to choose from pioneer or Sony
Components(at rear row) : Infifnity Refer 6500 or JBL 649
At front (Coxial ) : ? or JBL 265
Amp 4 Channel : Sony or JBL 640
Bass : JBL or Pioneer
Will be choosing good quality wires and dampnings too.
so your thoughts and advice pls
Self driven or chauffeur driven? Avoid Sony like the plague. Avoid JBL speakers.
For HU add JVC and Kenny to the list. Budget for decent wiring.
First of all, get components for the front. Check out Bull Audio, Digital Design, Helix Blue, etc.
Leave the stock rear speakers or swap with the fronts (if there is any difference between the two).
Add a 4 channel amplifier. Nothing beats JBL at VFM. Try to get the JBL GTO 100.4.
12" sub from JBL and local enclosure. Wiring from Scosche.
Should be doable at a smidgen above 30k.
^^^^^once you are saying to avoid JBL speakers again suggesting JBL...
anyway to op..
buy JBL TUBE sub..nothing beats it at that price..
Battle Ground Choices to make :
thanks to the community for helping me out :)
Hu : Pioneer 8350 vs JVC 926BT vs Kenwood X7013 (or 16)
Speakers : Infinity reference 6500 or Bull Audio BA-CS6 or JBL 649
AMP : JBL 100.4 or any other ?
Sub : JBLGTX1150 or any other ?
