shankarcams
I got a Stereo Dirac recently, and have done the measurements etc. and created the filters. I have created two paths for my Sonos - First, Sonos RCA -> 861v8 (MRC) -> 8k, and Second, Sonos Optical -> Dirac -> 861v8 No MRC -> 8k2. makes it easy for me to do an A/B.
Two standout comments:
1. The Dirac drops the output level by a massive amount. I would say 12dB to 15dB. This cut is in place even if filters are bypassed. I understand this is by design. Probably they use boost filters also instead of the MRC's cut only approach. But net effect is that the energy level drops dramatically.
2. There is no scope to fiddle at filter level with the Dirac. One has to set a response curve, and that's all one can do. The Dirac generates filters to bring the output as close to the response curve as possible. However it operates in the entire 20-20 range.
The overall feeling I have i that the 12-15dB attenuation makes the Dirac unviable for me. I like to listen to music loud, and with the Dirac, even 99 is not adequate.
The sound is probably better probably because I need some correction in the 300-500Hz range, which MRC can't do. Had it not burdened me with the attenuation I might have seriously considered the Dirac for music.
Also, the unit can't be sold. Of course it can, but the associated software license is personal and cannot be transferred. Also a matter to be considered.
Wish I had known some of this before I shelled out!
