nad 320bee
vishnu
how much is the price of 320bee?
also suggest a good pair of floorstanders below 18k which would go along with it
The c320bee has long been replaced by the NAD c325bee. I would suggest you consider that instead. No idea about price - you could contact LaKozy if you are in Mumbai. You should be able to get the old Wharfedale Diamond 8.4 floorstander below 18k. Can't think of any other suitable mate for the NAD at this budget - if you dont mind a bookshelf then PSB Image B25 in the low 20s.
I can suggest Polk Audio Monitor 50 and Jamo S-708 in that price reason. However, if you go in favor of Polk Audio, I'd strongly recommend you to bump up the budget a bit and go for Monitor 60.
