The
near field of a speaker is the region close to a speaker cone, where the sound pressure and acoustic particle velocity are not in phase. In this region the sound field does not decrease by 6 dB each time the distance from the source is increased (as it does in the far field). The near field is limited to a distance from the source equal to about 4 times the radius of the piston (speaker cone). So the smaller the speaker driver, the shorter the Near Field and likewise the larger the speaker driver, the longer the Near Field. Since the pressure fluctuates wildly in a complicated manner in the Near Field, it is forbidden to listen to any speaker in the Near Field.
The
far field of a source begins where the near field ends, and extends to infinity. Note that the transition from near to far field is gradual in the transition region. In the far field, the direct field radiated by most speakers will decay at the rate of 6 dB each time the distance from the source is doubled. It is always important to listen to a speaker well into the Far Field.
The above is only explained to clarify that the terms Near Field & Far Field are physics terms and not marketing terms invented by salesmen to classify small, medium or large speaker monitors. Since small speakers have small drivers thus a very short Near Field, it is possible to listen to them in the far field which is actually pretty close to the speaker. Whilst a speaker with an 18 inch driver will have a Near Field of almost 3 feet. The closest you can get to it is atleast more than 4 or 5 feet away to be in the Far Field.
