gudu
Need advice regarding lines on LED tv - Haier
Sir,
I brought LED tv of Haier recently 40 inches [FULL HD].
That was in april 2013.
I have set top box of reliance [ordinary, not HD].
Problem started when I started noticing horizontal lines which appear when yellow color pictures, or blue color pictures appear on screen.
Upon complaint, Haeir technical support team was at my place and checked for same and took photographs of same and told they will replace the set.
and they did. Replace the set.
They brought a new one. But in the new one also the same problem exists.
So I did complain again to technical team of Haier and they came and checked and told this time that the fault was not of TV but of Reliance set top box.
I need to know any of you facing same problem.
Is it really the set top box from which the horizontal lines are appearing?
Need help, please.
Sir,
Need help, please.
