need for A/C stablilizer?
gobble
Hi folks
I was looking at some A/C models and they come with built-in stablizers already. Yet the A/C vendo is insisting on an extra external stablizer to protect the PCBs . Is that really needed? Is the built-in stabilizer only good for the compressor?
SPONSORED ADS
SPONSORED ADS
gobble
You get inverter models but most would still recommend an external Stab.
That is exctly my question - what is the problem with internal stabilizer only setup? Or is it just an opportunity to make more sales?
G
mathan
Chennai
G
I too thought the same when I bought the inverter model a/c and did not install any external stablizer. The problem surfaced when there is a voltage fluctuation and the a/c automatically switched off as it was not able to boost the voltage or regulate it. The same happened when there was high voltage also. I had to install a premier 4KV voltage stablizer which costs around Rs.1200. The problem was solved after installing this stablizer. I think the inbuilt stablizer in the inverter a/c is good enough as long as there is no voltage fluctuation.
mshifi
hyderabad
G
Most of the inbuilt motors operate between 190 - 260. Any variation beyond this cannot is not safe for the motors as they do not trip.you need to provide an external device to handle the variations.
gobble
Ok but the stablizer the a/c shop is recommending is outside the upper range of the inbuilt stab. The a/c has 160-260V range while the 3rd party stab is 140-270V. So the device will not protect in case of over-voltage is that correct?
G
mshifi
hyderabad
the supply to the ac unit would be through the stabilizer, so any overload on the unit the stabilizer would trip.
sunilkm
I have checked Panasonic Interter models during the weekend. It is mentioned on the A/C and brochure that no external stabilizer is needed and it can take the voltage fluctuation ( 145v - 285v range )
SPONSORED ADS
