I’ve just brought a pair of raurk accolades and have a dennon avrx200 do you think I will need a power amp any suggestions welcome many thanks I also have b & W vm1 speakers and a rel sub many thanks
I think HT folks will be able to answer it better..but as ling as you calibrate the gain such that the SPLs are matched to account for differences in sensitivities you should be fine
I guess your AVR have no pre-outs, pls check. BTW you will not require external AMP to drive B&W, AVR itself have much power, go to Settings and increase sufficient LEVEL, that will work.
