Santhosh123
Hi. I need suggestion regarding AVR. Iam getting good deal on denon x4500h ( new, not used). Iam confused between denon x4500h and denon x3700h. Which one should I opt ?
Yes. Good pointIt's always better to opt for the latest one for better supportability. X4500H is a 2018 model, so getting the spare might be challenging if something goes south. Before pulling the trigger, I would check with the ProFx once on spare availability/supportability.
Ya getting for 30-40k less than x3700.Both AVR's are are strong performers. The X3700H is a newer model and adds support for 8K video, few video features and dual calibration audio settings but slightly less powerful @ 105 W/CH vs. 125 W/CH of the x4500.
Like @OM_2K19 said parts availability might be a issue, but if you are getting it at a price lower than the x3700 do consider it. 4 series is better built than the 3 series and adds Auro 3D and a front HDMI which can be a good thing as it is missing on x3700.
Hi Santosh,Hi. I need suggestion regarding AVR. Iam getting good deal on denon x4500h ( new, not used). Iam confused between denon x4500h and denon x3700h. Which one should I opt ?
Its a new setup. Planning q acoustics 3090i series 5.1.2. x4500 quoted 80k. 3700 above 1.25. Having said that every thing will become old with time.Hi Santosh,
Welcome to the forum.
Do you already have speakers, or is this a purchase for a bottom-up new set-up?
Like others have said, the spares issue is one you need to check.
Other than that, better to write to Denon seeking clarification about the support, going forward...
If your speakers are easy to drive, then the power difference between the two will not matter.
You have not mentioned a price, so, I'd venture and say this -- say if the 3700 is quoted at 1.2L or above, and the 4500 well under 1L, then worth considering the 4500, unless your use case demands the most recent bells and whistles. Else, don't worry and go for the 3700.
Just check HDMI, HDCP and VRR versions/support if you are into gaming and HDR support levels if you like recent movies.
Both I think have multi eq xt32.
Best and regards
From where did u get these quotes, i have been looking for 3700 and all the dealers were quoting above 1.4 lacs, i would happily go for 4500 if its comes within 75k with manufacture warranty.Its a new setup. Planning q acoustics 3090i series 5.1.2. x4500 quoted 80k. 3700 above 1.25. Having said that every thing will become old with time.
4500 is a better avr then 3700 even if it is an old model and you are getting it lesser then 45k. Easy pick if you ask me.I will even pick an used 4500 for 70-80k compared to 3700 at 1.25.Its a new setup. Planning q acoustics 3090i series 5.1.2. x4500 quoted 80k. 3700 above 1.25. Having said that every thing will become old with time.
Loudspeaker prices have come down. Avrs are still pricy. Amplifiers are from time to time bubbling around for half price sale in some sites. August is the time when supply demand would stabilise and prices could freeze at pre-covid levels.Have AVR/Speaker prices started to come down yet? I read somewhere that semiconductor prices are now easing.
I don't get warranty . As it was bought from usa but unused.From where did u get these quotes, i have been looking for 3700 and all the dealers were quoting above 1.4 lacs, i would happily go for 4500 if its comes within 75k with manufacture warranty.
Its with speaker package.. some ppl are quoting less.From where did u get these quotes, i have been looking for 3700 and all the dealers were quoting above 1.4 lacs, i would happily go for 4500 if its comes within 75k with manufacture warranty.
I don't get warranty. Ya price is attractivePrice is the game changer and at that price it is 4500h that makes sense. More powerful too plus lesser expensive for a very attractive price plus standard warranty.
If there are no spoilers for your other requirements, I don't see a reason to choose the 3700 over the 4500 at those prices.Its a new setup. Planning q acoustics 3090i series 5.1.2. x4500 quoted 80k. 3700 above 1.25. Having said that every thing will become old with time.
