Need suggestion on projector
haisaikat
Kolkata
Need some suggestions on projector. My company wants to donate a projector to one NGO who wants to use it for mostly displaying presentations and occasionally some educational videos. The max budget is Rs 50,000 and the need is for a easily maintainable and sturdy projector assuming the same would be used in village areas.
If you go with a LED projector, it might be better as lamp based ones tend to not survive rough handling. LG has good LED projectors.
Casio LED Projectors would also be good, You can avoid the lamp maintenance. Not sure about availability and price here.
I would suggest you to go with LG. Their series of projector were sleek and good to carry...I would prefer PA72G (or) PW800 from the LG.
PW800 is 2015 model which comes 5.5 x 5.5 x 2 inches dimension which means less than palm size.I have not seen the PW800 in person.But have auditioned the 72G, which is really good.I suggest you to take a demo of any projector before you buy.
