Onkyo TX-SR308 price
Cherian
Goa
Very confused after receiving wildly differing quotations for Onkyo TX-SR308.
A Mumbai store has quoted Rs. 26,500 and a Pune guy has offered the same for Rs. 20,000
Could someone guide me on what is the best price I could get it from in Mumbai?
Planning to connect it to Wharfdale 10.2 BS and a matching Centre for now and build from there on in phases. Please correct me if the combo seems off in any way.
The price of onkyo 308 should be around 20K or even less. Onkyo 508 should be around 24K. I would recommend 508 or denon 1611 ~ 24K.
Thanks Baiju. Will look at the Denon 1611.
The 508 appears to be a 7.1 AVR, which is a bit more than I need for my 10x14 room.
Spirovious/denom are organising a group buy offer for yamaha 667. The price will be around 24K if we can get 25 quotes else around 28K. It is singapore model and is 250V. If you are interested then send a pm to denom.
