? Your SOURCE device will govern the drive of the entire system's overall Gain structure and how successfully you're able to implement a Passive in the system.
? Usually, source impedance of the Drive device should be as low as possible, preferably less than 100 ohms.
? The voltage output from the SOURCE device should be as high as possible, preferably above 2.0 volts, and the higher the better.
? The Sensitivity of the Power Amplifier's input should be 1.0 volts or lower, preferably the lower the better.
? The Input impedance of the Power Amplifier should be as high as possible, preferably 47k ohms. [ It is possible to tackle input imp as low as 10k ohms also but only with a very strong & very low imp drive from the source ].
? The Interconnecting cable between the Passive's outputs and the power amplifier's inputs should be restricted to 0.5 metres of a very low capacitance type in order to arrest high frequency roll-off.
IF & ONLY you're able to address most of the above properly, only then should you consider a Passive device.
Passive devices can be of 2 Types : Resistor based or Transformer based TVC. Both are successful and work well.
Finally, a well setup passive in a system is one wherein your playback is conducted between 10 o'clock to 2 o'clock Volume Level position.
If you're able to adhere to the above, you will be well rewarded with a clean, detailed, ultra low-noise sound that the passives are supposed to.
