Picture Size - Not working in 51F5500 - USB Storage
agriz
Pondicherry
I connect my usb device to watch movies. But they are not resizable. So The black bar in the top and bottom remains. I want to zoom or full screen the video which is not possible to do for usb videos.
Where i can find the settings to zoom the videos?
Alternatively, Can i change the video's height and width manually with some software to show it in full screen size?
What is the best width and height to have full video?
What is the TV model you are having and what is the file resolution (in laptop play suing VLC and it shows the width x height)? Your problem is that the files you are using are not Full HD and at the same time your TV is not upscaling them properly. Increasing the width and height without substantial loss of picture quality may be difficult with free softwares as they also need to upscale and employ good algorithms.
Apart from the above, do you have a laptop with HDMI out or a media player at home?
