Pls Suggest Speaker cable for my HT
aryan77
mumbai
hi everybody
After long search i have finalized Denon AVR1912 with Jamo hcs 606, now question is which speaker cable shoud i use and of what gauge, my room size is 10ft x 14ft . From AVR to REAR spker lenth is 33 ft , and from avr to front and center is 5ft. Shoud i use seprate cable for front and rear.
Seriously, use this chart to determine the size of wire needed. Remember the larger the wire gauge, the smaller the diameter.
http://www.belden.com/docs/upload/Sp...tion_Guide.pdf
Shielding is a metal sleeve over a signal wire to keep external currents in adjacient wires from interfering with the signal. The currents in speaker wires are not likely to need shielding unless you run the speaker wires in the same conduit as mains or input signals. Speaker and CAT 5 cables should never be run in the same conduit with mains wiring for safety reasons. The power and speaker cables should not be bundled together, and shoud be kept apart by 15cm (6 inches) or more.
For a home theater, the Belden 1307 is more than capable.
http://www.belden.com/products/catal...d/19-31_37.pdf
hi everybody
maybe you can consider chord silverscreen for the front/center and cheaper chord cable like classic/campana etc for rears.
