Hi there HTPC experts,
Proposing a HTPC build with following specs. Please comment...
First my requirements:-
1. No gaming absolutely
2. Rip DVD's often; BD-ROM's occasionally
3. Watching HD and SD movies. Already have a Pioneer BD player. This HTPC would be connected to my Onkyo HT-S3500 using HDMI cable. Output would be routed to my existing BenQ projector or proposed x30d plasma by using a hdmi splitter (This is to enable family to watch tata sky (SD) and low-res movies) :lol:
4. No need for recording TV, youtube etc.
5. Not planning to go the NAS way
6. About 6-8 tb of internal storage
7. Wireless required (only for Keyboard+mouse)
8. Need plenty of USB 2.0 and 3.0 ports
For the above requirements, after browsing through HFV and other threads, have decided upon-
-Processor*: intel i3 2100 or 2100t (not sure what the "t" postfix means)
-Mobo: Asus P8H67 or equivalent
-GPU: GT 440 or GT 520 (fanless and hence attractive) (can hear Sam swearing by GT 440
-Cabinet: Cooler master or Zebronics with max 400 w psu (not looking for media center cabinet) (should have plenty of internal bays for HDD's)
-RAM: 2 x 2GB corsair
-HDD: max overall 8tb - Seagate or WD (will start with, say 2TB and will be adding hdd's in phases, say once in 4-5 months) (Not looking at SSD - does not seem to be worth it)
-BD drive: LG or ASUS (are BD read + DVD write drives available?)
-Suitable remote from HP, wireless keyboard+mouse from Logitech/Belkin
-Would be running XBMC on top of Win7 Premium
Budget: 35k max
* If a Dual Core G620 is enough for my above stated requirements, then would go for it along with suitable mobo (cost significantly comes down).
Please comment and give your suggestions on the specs - particularly if anything would be an overkill. Thanks in advance.
Athulan
Budget: 35k max
Athulan
