QUAD S-2 Bookshelf Speakers
Status
Not open for further replies.
HiFiVision
Super Moderator
The QUAD S-2 is a Ribbon Bookshelf Speaker
Quad has always prided itself as providing the complete solution to music lovers. Each Quad component marries perfectly to other parts of the hi-fi system and is designed with one target – to be ‘The Closest Approach To The Original Sound’.
Quad S Series loudspeakers fulfil that objective admirably. Sporting a new ribbon treble unit aligned, through sophisticated crossover networks, to Quad’s advanced bass-midrange drivers, each and every loudspeaker in the range delivers all the nuances and passion of the original performance.
Order your QUAD S-2 Speakers NOW!
Specifications of the QUAD S-2 Bookshelf Speakers​
General Descriptionbookshelf
Enclosure typevented box
Transducer complement2-way
Midrange driver125mm Woven Kevlar®
Treble driver45 x 12mm true ribbon
Sensitivity (1W @ 1m)87dB
Recommended amplifier power25-150W
Nominal impedance
Minimum impedance4.5Ω
Frequency response (+/-3dB)48Hz – 22kHz
Bass Extension (-6dB)37Hz
Crossover frequency3kHz
Cabinet Volume (in litres)10.3L
Dimensions330 x 180 x (260 + 30)mm
Net weight6.1kg each
FinishMahogany
Status
Get the Award Winning Diamond 12.3 Floorstanding Speakers for just ₹77,000/Pair.
