Question regarding Playing 3D movies in Tv
  • Thread starter Deleted member 71491
  • Start date
D
Guest
I have a 3d video
when i play in computer the screen is split in 2 half's left and right.can i play this type of video in TV.is there any conversion needs to be done?Can i use passive 3d glass to view this content?
Thanks all
It is a Side by Side (SBS) 3D format and you need a 3D TV to watch it. In the TV it will appear as split screen and you need to select 3D mode as SBS. Any media player can be used to play in PC. TV USB can also be used if the format (usually mkv) is supported.
If you don't have a 3D TV then use kmplayer to convert it to anaglyph format and use a blue-red glass. You won't see any colors other than red and blue.
Remove that link to the torrent.
