tellanand
I intend to buy Klipsch Reference Series speakers in Chennai. The model numbers are RF-52 (x2 Towers) + RC-62 (Center) + RS-42 (x2 Surround) + RW-10D (Sub). My room size is 15 x 11.
The Onkyo dealer in Chennai also sells Klipsch speakers and is pushing the Onkyo SR606 with it. The dealer is quoting Rs.150,000 for the speaker set (and says can offer 8% discount; ie works out to Rs.138,000). However, I also like the Yamaha RX-V663 and want to know if 663 will match with these speakers.
[1] Are other speaker brands (Yamaha etc) equivalent to the Klipsch reference series (interms of price and performance) that I should consider before making a BUY decision?
[2] I've read good and bad things about both Yamaha and Onkyo receivers. In particular, can you comment on Onkyo SR606 and Yamaha RX-V663 wrt their performance and support in India?
best regards
- Anand
best regards
- Anand
