senthil.obly
Hi Guys,
Please suggest a best audiophile amp. Thanks advance
Where I will get in Bangalore.heard the rega brio. Very good amp with lots of power. There is another amp from audiocontrol rialto 600. Do give them a listen. You could audition them in bangalore
Prosonics deals with audiocontrolWhere I will get in Bangalore.
Tusker audio for regaWhere I will get in Bangalore.
Bro can you suggest all the good audiophile grade amplifiers under 80k.Tusker audio for rega
Can you please give me particular model in each manufacturer.Look at marantz, Yamaha, rega, audiocontrol. Best would be to audition. If you already have speakers, you need to match to that too.
Marantz you could look at 6 series and above, Yamaha AS800 and aboveCan you please give me particular model in each manufacturer.
Making it simple for you if you like fuller warmish sound signature go for Rega. And You value features over SQ with balanced SQ Go with Audiolab 6000a (I own it)Hi Guys,
They are all good brands. You need to check the specs, reviews, etc and do a bit of your own research based on your own requirements and preferences. What seems good to me, may not seem good to you. So please research and shortlist the models. Probably then members here can help you finalize.Can you please give me particular model in each manufacturer.
Please suggest me modes from marantz, yamaha and Denon which sounds very good .In the present condition of hifi, sound quality is just not the sole criteria for equipment selection. We have to consider service. If you go for high end, rare units, sound wise you will be more than satisfied. But once anything happen to it, if it looks good, can be used as a show piece on your shelf. Since these are not mass produced, spares are scarce. Most of them will require chip level servicing which is not easy and is expensive. I suggest you go for brands like Marantz, Yamaha, Denon etc. They sound pretty good and comparatively easier to service.
I like warm sounding Amp. Right now I have Dali zensor speakersWhat kind of sound do you like the most? Bright/warm/neutral? The ones you've listed are quite bright and need some care when pairing with the speakers. I have heard the Marantz pm6006 paired with Klipsch bookshelves, and my ears cringed. So, you may have to be quite specific about what type of sound you prefer. Finally, nothing can replace auditioning the amps and speakers. Time-consuming, but lets you stay with a system for a long time.
I see you've set a budget of 80k for the amp. What speakers do you have?
