I have an Onkyo remote which requires a remote code to be entered. I have not been able to find the remote code for the WD TV LIVE. Anyone here could help me with a code that will work? Thanks in advance.
I have read that WD remote codes are only present in the Logitech Harmony range, else you would need a learning remote to learn the codes off the WD remote. Hence you may want to check if your Onkyo remote is a 'learning' one.
