Samsung HT-C6530 Home Theater not able to play 1080p DTS MKV files, but..
scansbar
Montreal
Hello,
I have spent tons of hours and days trying to figure this out so any help or explanation would be greatly appreciated.
I have a Samsung HT-C6530 Home Theater System that is able to play 720p MKV files that are encoded with the DTS Audio codec on a DVD disk, but it is not able to play 1080p MKV files that are encoded with the DTS Audio codec on a Bluray disk as the audio stutters and then it is mute.
I tried it on a LG Bluray player and it can't play it either.
Now I'm assuming that the players can't decode the DTS so my only option is to encode it with lets say AC3 and it will work.
I don't understand how it can play the 720p and not 1080p. Is it because there is too much data to process?
Any help or explanation would be greatly appreciated as I can't figure this mystery out.
The Bluray players advertise that they can decode DTS.
Thank you for reading and hopefully you can assist as I'm backing up my movie collection and before it grows I'd like to know what are my options.
Take care
Mark
This is the main disadvantage of Sony Samsung Philips HTiB. Their AMPs come with limited codec decoding support, so if you download or rip a Bluray and play it on the player via USB or by burning on disk, if the codec is unsupported it won't be played. Nothing wrong with the machine but its the codec combinations which are not being decoded by the player. Play the same file on PC and it will work.
Post the mediainfo details of your mkv file.
Hello,
Stream 0
Type:Video
Codec: H264 - MPEG-4 AVC (part10) (avc1)
Language: English
Resolution: 1920x1080
Frame Rate: 23.976215
Decoded format: Planar 4:2:0 YUV
Stream 1
Type: Audio
Codec: DTS Audio (dts)
Language: English
Channels: 3F2R/LFE
Sample rate: 48000 Hz
Bitrate: 1536 kb/s
Thank you.
Hello,
Stream 0
Type:Video
Language: English
Stream 1
Type: Audio
Language: English
Channels: 3F2R/LFE
Bitrate: 1536 kb/s
Thank you.
Please post the text view of mediainfo..you need to install this app to get the info..MediaInfo - Download..I think you copied from vlc mediainfo..
Your right, straight from VLC, your good.
General
Complete name : D:\My Backup.mkv
Format : Matroska
Format version : Version 2
File size : 6.43 GiB
Duration : 53mn 53s
Overall bit rate mode : Variable
Overall bit rate : 17.1 Mbps
Encoded date : UTC 2012-09-17 01:13:15
Writing application : mkvmerge v5.8.0 ('No Sleep / Pillow') built on Sep 2 2012 15:37:04
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 53mn 53s
Nominal bit rate : 12.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.241
Writing library : x264 core 125 r2208 d9d2288
Encoding settings : cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=11 / psy=1 / psy_rd=1.02:0.04 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=12 / lookahead_threads=2 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=7 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=120 / rc=2pass / mbtree=1 / bitrate=12000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=40000 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Duration : 53mn 53s
Bit rate mode : Variable
Bit rate : Unknown / 1 509 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossless / Lossy
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : en:00:00:00.000
00:01:39.099 : en:00:01:39.099
00:07:45.006 : en:00:07:45.006
00:17:15.534 : en:00:17:15.534
00:24:05.194 : en:00:24:05.194
00:33:40.810 : en:00:33:40.810
00:42:41.684 : en:00:42:41.684
00:52:37.112 : en:00:52:37.112
The DTS audio you are trying to play is lossless DTS-HD MA codec which is not fully decoded by your player.
Could you please tell me what is the error message you are getting-it's not playing the file at all/audio stutters/No audio only video..I will let you know how to proceed further.
The audio will play choppy or mute itself out but the video will play. Thank you for helping.
Mark
Download tsmuxer from here tsMuxeR 1.10.6 - VideoHelp.com Downloads
open tsmuxergui.exe-->add the file-->deselect video stream(h264),select audio stream only-->check option Downconvert DTS-HD to DTS-->check output option as Demux-->start muxing-->you will have a .dts file in the folder.
Download mkvmerge gui version 5.7.0 from here-
Code:
http://www.mediafire.com/download/qsso53276fpb087/mkvtoolnix-unicode-5.7.0-setup.exe
Install it-->Open-->Go to File-->options-->mmg-->verify whether Disable header compression removal option is checked.
If not check it and restart mkvmerge again.
Now add the mkv file, deselect the DTS audio from there-->add .dts file you extracted-->mux the mkv file-->now try to play it.
let me know if you have any issue.
