Samsung series 3 does not play hd
sudhirbhosale
Hyderabad / Mumbai
I have Samsung 32" series 3 HD ready TV.
Whenever I tried to connect to HD source i.e. HDMI out from DVD playe OR from Laptop no picture / audio.
Getting message on TV screen "No signals"
Same I tried on other TVs with same cable, working fine.
Any solution for this?
Thanks in advance !
Thanks in advance !
What is the TV model ? Do you mean to say when you connect to another TV of same model there is not issue ?
Is there a series 3 with Samsung?
I always thought they made series 4 and above..
Is it HD compatible in the first place?
I talked to Samsung engineer about this issue. He said series 3 HD ready use old HD technolgy. So I nned to use HDMI cable 1.2. After using different cable now I am getting picture. But no audio now.
Any help on this
Try connecting different HDMI port if any. else you can alternatively connect audio RCA (red and white) addition to HDMI directly from DVD player to computer speaker via 3.5 stereo jack. Tv's speaker anyway wont sound that great.
