Segate Barcuda 7200 rpm HD Not recognized by xtreamer pro ?
mdharan
He!lo members !
Recently i bought a 2tb Segate Barcuda 7200 rpm Hard disc which is not recognized by xtreamer pro and also in my bluetimes coopa 3d player.
any suggestions regarding ....
Murali.
Does it get recognised if connected to a PC?
Is it pre-formatted? If so what is the format?
I think xtreamer pro can be accessed through ssh. If you know little bit of linux check if the HDD is already recognized by the OS using the command dmesg
Check if the HDD is partitioned using GPT or MBR..if it's in GPT it won't be recognised in xtreamer pro or 3d player.
To know..connect to pc..Disk management-->right click on the disk-->Properties-->Volume-->Partition style.
amit,
how did you get it working in detail?
assume GPT instead of MBR.
which blocksize when formatting?
tried a lot on iXtreamer, but didn't get it working.
regards
al
Hello every one,
My Hard disk after formetting in the computer xtremer and coopa mps start recagnising it thank you all.
Murali.
