akshya1979kumar
I got an old receiver which can decode DTS true HD but its not 4k. Have a projector installed which is 4k. So when i am playing 4k movies the receiver automatically downgrades 4k to 1080p.
i was thinking of getting a HTPC from which i can have separate output for projector in 4k through HDMI and audio output in true HD through separate HDMI.. is this really possible if yes please suggest me HTPC build.. my budget for HTPC is around 80k. If above said is possible then i think its better to spend 80k on HTPC rather than to spend 1.5 on receiver
thanks
thanks
