Single ended tube amp
Chandigarh
Generally SET are low wattage amps. Is there any way to increase wattage by using tubes like KT150 or 845? Many people have experienced such combination and they were quite successful in this circuit.
Any one from forum have experienced these tubes to be used in SET amplifier?
Here you go..
There are high powered tubes but those amps are really expensive. Tubes like the 211, 845, gm70 are usually used as SE designs. Kt120 are usually used as push pull though I don't know why.
Lyric audio a German brand makes SE kt150 amps.
Our local brand, lyrita audio also makes a gm70 amp. Mauve someday lyrita will buy lyric audio. Viren?
Virenji makes SET GM70 integrated or mono blocks. I used to own them earlier and it is raw power.
