Small query on TataSky HD/HD+
ontherocks
Pune
My Tata Sky HD box seems to have gone kaput. I need to test it.
Could you guys let me know if you see any image/video if you connect it to your TV via HDMI but without any connection to the satellite dish cable?
I mean some screensaver or something or anything.
When cable is disconnected from HD+ box
Dialog:
Technical Problem
Your digicomp is not receiving signal
etc
if i press (select) to continue, i get the Organizer menu for settings.
Thanks guys.
Tested it with a friend's TV who doesn't have TataSky.
It turned out that the STB is ok. So my TV's HDMI port has gone kaput :(
