Sony Bravia klv-37S400A colour problem
ajayigi
kerala
Hello All
I have a Sony Bravia KLV-37S400A. few days back when i turned on the tv the colour became blurred on the images and coloured part of images shows dark blur and some other side shows light colour blur. My warranty period is over. I used hotair as a test for any dry probs on main board and reseated all connectors but no change.
Any idea?? Would you suggest me that what might be the reason behind this?
Which section would be the resulting point??
Am expecting a kind helping hand...
Thanks in advance
By Jaymon
I have taken many photos of the problem and attaching the same. You can see the blur/washout colour in those screenshots so that it would be very helpful for you to understand the real core.
Are you using a set top box ? Then check whether the settings are matching ?
Also check the saturation / hue / contrasts. Sceens like this can be caused by high contast / hue / saturation settings
How is the pictures when other sources are connected ? like a DVD player or movies on a USB stick etc ?
If the problem is still there call service. IMO sony has an excellent service back up.
