For Sale SONY RADIO 5 BAND Vintage Big ICF - 6700 W for Rs 6000 only!
Mogami Cables
hemantwaghe
Banned
It is crazy radio real KRAZZY looks! Really it gives your table top some techno villain feel!
I am not into radios so did basic testing. Able to tune up some FM stations , one MW not able to tune any SW ( only noice) But operations seems complex . Frankly I do not have patience and want to sell it . On the safer side I cannot say it is fully working as I amg
Below is specs taken from Shortwave Receivers Sony ICF-6700W
Condition is very good buttons golden hue is slightly faded, but colour is matt grey which is scratchproof , so condition is very very good.
Google SONY ICF 6700 W and it throws a lot of information.
It can run on batteries battery bay is untested.
There are 2 handles each side and provision for belt.
Has a small VU Meter and very big antenna.
From each corner it oozes build quality.
My price Rs 6000 only Shipping will be additional Rs 700
See the photo album
Sony Radio Photos by hemantwaghe | Photobucket
http://i1304.photobucket.com/albums/s530/hemantwaghe/Sony%20Radio/IMG_20150520_125105_zpsxr1d8h0o.jpg[/IMG [URL=http://s1304.photobucket.com/user/hemantwaghe/media/Sony%20Radio/IMG_20150520_125009_zps3pf7e8fy.jpg.html][IMG]http://i1304.photobucket.com/albums/s530/hemantwaghe/Sony%20Radio/IMG_20150520_125009_zps3pf7e8fy.jpg][/URL]
ICF - 6700 W
The Sony ICF-6700 W/L is a multiband shortwave receiver with the typical square design very similar to the ICF-6800 W, with this set it can be easily confounded. The conventional double conversion set with manual preselector (covering longwaves only in the L variant) is technically less problematic then the better known ICF - 6800 W suffering very often from "dead" band segments.
ICF - 6700 W the little switch next to the band selector activates AFC when in FM mode, longwaves not covered
Double conversion superhet, 1st I.F. 10,7 MHz, 2nd I.F. 455 kHz
Digital frequency display, 1 kHz
FM, MW, LW (only in "L" version),
SW1 (1,6 - 10 MHz), SW2 (11,5 - 20 MHz), SW3 (20-29,5 MHz)
AM, USB/LSB, FM (VHF)
Selectivity -6 dB/ -60 dB
3,2/9,1 (N) / 5,2/21 (W) kHz
Sensitivity 6 kHz
AM 1,2 - 1,3 uV, SSB 0,8 - 0,9 uV
RF gain, preselektor
The Sony ICF-6700 has it's strange rectangular "bread bin" shaped cabinet in common with the ICF-6800, in contrast to the '6800 which is a double conversion receiver based on the Wadley Loop cirucuit is the ICF-6700L a conventional double conversion superhet with a frequency counter.
The receiver is 45,3 x 18,4 x 22,7 cm wide and has a wight of 5,5 kg, it has carrying handles on both sides and You can attach a carrying strap, but in fact it's not a portable but rather a desktop shortwave receiver.
The ICF-6700 can be powered from 110/220 V mains or from six UM-1 / mono cell batteries, the battery compartment is located at the top of the receiver, a world time conversion table and band allocation plan is printed in the cover.
The left third of the front panel is taken by the speaker grille, just below, You find the headphones jack and the rotary volume, bass and treble controls.
On the front panel, You find the main power switch and the typical round signal strength meter in the left upper corner, a tiny yellow pushbutton lets You activate the dial illumination for a few seconds when the receiver is battery powered, next to it, there is a switch to turn off the frequency counter to save battery power.
Just below, You find a rotary bandswitch for FM, mediumwaves and shortwave bands SW1 (1,6 - 10 MHz), SW2 (11,5 - 20 MHz), SW3 (20-29,5 MHz). Only in the ICF-6700L version, the longwave band is covered, in this case, the switch at the left is not used to activate the AGC in FM mode but lets You select between long- and mediumwaves.
L: mit Langwelle W: keine Langwelle
On the right half of the front panel, You find at the top the small dark red LED frequency counter and next it the preselector dial, the preselector control is located just at the right of it and has to be carefully tuned for a maximum S meter reading after each frequency change.
Below, You find the horizontal frequency dials, a mechanically moved pointer indicates the active frequency range.
The big tuning knob is rubber coated and can be operated without backlash. At it's left, You find the modes switch which also selects the wide and narrow i.f. bandwidth filter and the RF gain control.
The R.F. signal coming from the antenna has to pass the preselector and an amplifier stage and is converted to the first intermediate frequency of 10,7 MHz in the first mixer, after having been mixed to the second i.f. of 455 kHz, it has to pass the i.f. bandwidth filters and is handed over to the AM and SSB product detector. In the FM mode, the receiver acts as single conversion superhet with the standard i.f. of 10,7 MHz. This frequency used as first AF in the AM bands too, is the reason for the gab in frequency coverage between 10 - 11,5 MHz
In practical use, the ICF-6700 is a receiver straightforward to operate. In contrast to the cumbersome electronic and machnic design of the ICF-6800W, the ICF-6700 is based on a standard double conversion design connected to a frequency counter, it's sensitivity is slightly below that of the ICF-6800W, and the i.f. filters - similar to the ones used in the early versions of the '6800, are not that sharp. When You operate the preselector correctly, it performs well on the bands. For single sideband reception, You have to turn the tuning knob with caution as the receiver has only one tuning speed and no fine tuning.
The ICF-6700L is a very nica example of a double conversion shortwave radio with a convetional frequency counter, has the same unique design as the ICF-6800W and is less prone to fail, so less troubles with hafing it repaired. After some disillusion with buying a used ICF-6800W, You might consider looking around for a well performing ICF-6700.
BUYING, SELLING or TRADING indicates your automatic and mandatory acceptance of HiFiVISION.COM Trading Rules and Guidelines!
Do not blindly trust every seller or buyer! Protect yourself by following the below safe trading tips.
Safety Tips
For Buyers
  1. Always meet the seller at a safe location and inspect the item before purchasing. Following this one rule will help you avoid most scams.
  2. Watch out for unrealistic offers. If it appears too good to be true, it probably is. Unrealistic offers are used to motivate purchasers to make hasty decisions.
  3. Always verify the seller's credentials. Ask the seller to provide a photo ID and proof of address.
  4. Ensure that the product you are buying is not stolen or fake. Always ask for a purchase invoice.
  5. The best way to transact is to collect the item and pay at the same time. Never transfer funds or use a debit/credit/atm card to pay someone you do not know before collecting an item.
  6. Ask for clear information on condition of the item, price, payment and delivery method.
  7. Use only those payment methods that you trust and are familiar with. Never give out your financial information.
  8. It is recommended to purchase items directly from the seller.
  9. Always test the functioning of the item before purchase.
  10. Do your research on comparative prices for the product.
For Sellers
  1. Try to take the full payment at the time of the delivery. Remember to use a safe location to meet.
  2. Watch out for fake currency and money orders. Be aware that banks will not honour fake currency/money order and will hold you responsible for it.
  3. Verify the buyer’s credentials if necessary.
  4. Ensure that your product meets the features you list in your ad to avoid any misunderstanding with the buyer.
  5. It is your responsibility to prove that the product you are selling is genuine and not stolen by providing the necessary proof of purchase.
  6. Do not share your financial information except the one required for payment.
