As mobile mic have some background noise cancellations in place, roughly how much it would be accurate compared to dedicated sound meter hardware device?
Not accurate at all.
If you use a calibrated mic then you'll be able to get frequency response fairly accurate, but for spl, it's not usually going to work
Yes the app would give a good idea for that purpose
Depending upon how frequently you are consume the setup, its ideal to keep the volume at your listening position below 65db in everyday use.
Ones in a while you can blast of course, after all they are called "Loudspeakers".
