Speaker Switch
demigod
Pune
Hi All,
I need to connect a pair of speakers to, 2 amplifiers. Could you please suggest a speaker switcher?
Check the DIY section as I believe our FM spiro had made a DIY speaker switcher box using the regular power line switches. I think it suits to your requirements as well.
I have read somewhere that running an amp without load would damage the amp. Is there a way to ensure the amp switches to some dummy load when it is not in loop with the speaker? Using just a switch based selector would not do it.
Sent from my A0001 using Tapatalk
Use an 4PDT ON-ON switch, its always connected to one of the loads.
Sent from my SM-C701F using Tapatalk
