Speakers for a rega brio
arj
Moderator
Staff member
Someone I know is looking for a good floor standing speaker in a 1-1.25 L range to go with a rega brio . Any suggestions on a good match ?
What is specifically required is a floorstander . Room is 18x 30 l shaped with a 12 x 14 section on the side. At this point the rega RS3 is in consideration and want to check if there is anything better .
Music is old Hindi LPs
Sent from my iPad using Tapatalk
You can audition Tannoy also, matches well with Rega. I have Tannoy revolution XT 8F with Rega ElicitR...Brio amp is little on brighter side....
Sent from my SM-J710F using Tapatalk
Since you are in Bangalore go and visit Jochen Semler. The new Blumenhofer Fun 13 Mk2 that is on demo there is a fantastic small floorstander. And your friend has to stretch his budget only very little bit by 25 K.
Great suggestion. i was under the impression they were 2 Lakhs+ but should have reached out to Jochen.
