ivoidwarranty
Hi all,
I've been setting up a music system for a hall of 1500 sft (commercial space). We wanted ceiling speakers from the beginning so we've got 10x ceiling speakers (specs below) installed in the false ceiling with parallel wiring to a central cabinet. I want help in laying out the setup, identifying the amplifier (mandatory) and anything else that may improve the audio quality of our setup.
Requirement and usage:
Need recommendations for the following:
Thanks in Advance.
Bala
- The system would be playing south indian filmy/classical music at least 10 hours a day everyday - only stereo.
- Music would be mostly streamed from online sites / online radio (typically mp3 streams >= 128kbps)
- The PC used for streaming is Intel Atom D425KT based with in-built Intel HD Audio and one PCI slot / USB option available for sound cards [We would be using in-built audio to start with, but could potentially add a stereo sound card based on the difference it can make to the audio quality and the price]
- Speakers we've got installed are 10 x Boston Acoustics CSi8051 Specs here (5.25in / 8 ohms / 6W RMS / 10W Pmax / No LMTransformer) We would be using 5 speakers per stereo channel.
- What speaker configuration (parallel / series / hybrid) to use? Is it possible to make a setup with all the 5 speakers per channel connected to a single amp without using 100v lines / LMTs?
- Can we use the two outputs in the above amplifiers to drive 2x8ohm speakers each in parallel? / What are the two set of output lines in the amps for?
- Is my RMS power calculations right? Any tips in Amp RMS rating to go for?
- What stereo amplifier/s do you guys recommend for the above setup?
- Should I get a PCI/USB sound card for the PC for my usage (online streaming)? Would there be any noticeable difference? If yes, recommend some good stereo sound cards.
- Any reviews about the speakers we got? Should we dump these speakers and go for some other ceiling / book shelf / floor standing.
Thanks in Advance.
Bala
