Presented without comment:
Archimago's Musings: 24-Bit vs. 16-Bit Audio Test - Part II: RESULTS & CONCLUSIONS
If one has super transparent system,its very obvious....
There were separate tests for very expensive systems as well as for audio hardware reviewers who one assumes would have revealing systems. The results were the same... or, as in the case of the reviewers, worse.
even in the 50s experiment conducted at the time using speakers and playback equipment( what can be considered primitive to our current technology) audience were unable to tell the difference between live and recorded music.
Astonishingly enough these kind of tests, and results, go back even further, having been done with 78rpm discs played on acoustic-horn gramophones. Even then, the audio industry was already learning tricks, and the small orchestra had adjusted its sound to be as close as possible to the gramophone.
24 or 16 bit? It is a myth. HiRez is only useful for recording engineers.
Anyone with first hand experience of comparing NormalRez and HighRez in their own setup using the same song?
What's your experience?
Do 320kbps mp3 files really sound better? Take the test!
The REDBOOK standard was set after an extensive research. That's our limit and anything more is pointless.
http://www.avsforum.com/forum/91-au...-high-resolution-audio-test-ready-set-go.html
There are some music files in standard and hi-res formats (originally hi-res). You can download, listen and decide for yourself. Ofcourse a lot depends on the capabilities of the system and the listener too. If you are not able to find a difference, good for you. Translates into lot of savings.
I for one am quite impressed with almost all 24 bit recordings. May be for the reason Shivam has mentioned. Those who create hi-res albums sell it at higher price. To sell it at a higher price, they need to sound better. In order to achieve that, they record and master it well.
If CD was introduced with lot of research, I am sure DVD which is 24 bit would have been too. 44.1 khz may define the frequency limit, but what limits 16-bit is not clear to me yet.
However, it might not have been the best choice for the standard. I've been reading some off JJ Johnston's posts (Gearslutz, Hydrogen Audio) and it seems that, not for any unhearable-by-humans-anyway high-frequency content, but for easier reconstruction filter design, Sixty would have been a better magic number than 44.1. The world didn't go there.
No wonder I still enjoy my CDs.
'Hi-Rez' or not but at least the music released as 'Hi-rez' has good recording and mastering most of the time.
