Subwoofer under 10k
grepkapil
Delhi
I m under budget. I am planning to buy active powered speakers..either Audioengine a5 or Swan 1080mkii...that I will be playing mainly with my laptop and pocket media player/iPod etc.
I am not sure if bass would be enough with these speakers. So I may buy a decent(inexpensive) subwoofer. Please suggest me one under 10k.
( Audioenine a5 has subwoofer out option, whereas swans does not have sub out. )
-Kapil
Yeah, m50w is a good 2.1 setup. They are available in india. But I think 2 monitors + 1 sub would be a better option...than any 2.1 multimedia system.
-Kapil
Thanks..I know bout hifinage.
Guys on this forum, please suggest sub under 10k(or should I assume none exists?)
-Kapil
-Kapil
Yes. there is a good subwoofer for 12K. Sonodyne roarr 108. U might have to ask for discount & the best price you might get is around 11K. Try your luck.
-Kapil
For your kind of listening, other than the sonodyne suggested by elangoas (he beat me to it ;)), I would recommend the Norge NSW 100 with a passive radiator. The latter is more suite for music while the former is more apt for movies, IMHO. Take your pick but dont go for a multimedia sub, therefore that system with a sub pre-out becomes mandatory.
http://www.norgeaudio.com/
HTH
