D
Deleted member 15865
Guest
Dear friends,
My current (main) system is in my signature below. Having upgraded my source and preamp from what I started with two years ago to the CXC/CXN combination and Lyrita DHT, I now have started to feel like I should look at possible upgrades to the downstream components that have served me so capably from day one - the capable Audiolab 8200A (I use only the poweramp) and the lovely Castle Knight 2 speakers. No way am I feeling compelled to upgrade but if I am truly convinced that an option (poweramp plus speakers) that’s within my budget would serve my objectives well, I would consider the upgrade. Otherwise I can continue enjoying my system for years.
So here are my objectives:
1. Should maintain or improve upon the natural tone, sweetness and slightly warm signature of my existing setup. The current system is very versatile (as my music taste is) but excels at the vocal/mid-centric genres. Sparkle is needed, but should have a sweetness to it. Non-fatiguing naturalness is a must. Bass should not overpower, but provide body to the voice and instruments.
2. Provide a bigger sound than the current combo, ideal for a 330 sq ft living room (rectangular with the system along the breadth, which is kind of ideal). But I’d be playing mostly at low and medium sound levels. Idea is that even at low volumes the sound should be clear, with no loss in fidelity.
3. Musical (and emoting) system that does well with the microtones... something that sings well. I feel my current system delivers this (within the limitations imposed by its price range) and I’d not want to lose it for punchier sound. Most mass market products miss this part. The more musical options seem to be niche.
4. Should have better bass extension (not volume or thump) and lesser roll off on HF than my existing combo. This is so that I should be listening to more of the music on the track, something I know my existing system has understandable limits in serving.
5. Open to FS as long as they have musical bass. Not open to adding subwoofer. But happiest with BS (small/large) options.
6. Speakers that are less sensitive to placement, and produce excellent imaging and soundstage. The current combo has great soundstage, but compels me to sit in the centre to experience its beauty. Of course it’s enjoyable (with all details) from anywhere in the room, but the spatial separation is experienced only from the center.
Budget: About 2 lacs for the poweramp and speakers. Extendable to 2.5. (Don’t feel comfortable buying pre-owned unless they come in the combo and I can listen to them before buying)
In fact, if there are some speakers which can use the poweramp of the 8200A well enough and don’t seek more power, but can get me my objectives as above, I don’t mind putting a large part of that budget just on the speakers. On the other hand, if there are any tube power amp and full range speakers that can serve my purpose but available in this price range, do also suggest.
I’ve been doing some of my own research on this. And though I haven’t demoed, but by reviews and user impressions I think my ideal could be more like Harbeth speakers (my kind of sound preference) and Naim amps (musical). But they’d not be in my budget unless I get good deals in pre-owned (with above mentioned limitation). Something like Rega is lower cost alternative to Naim and Linton Heritage to Harbeth, but then I have to feel sure that they are sufficiently significant upgrades. I’d be wary of sideways or incremental upgrades. I’d hate if I buy something and it doesn’t deliver, just not a ‘try, if don’t like, resell’ person.
Kindly read through above to understand my objectives, preferences and needs and then suggest. Looking for quality of suggestions than quantity. If you need any more info to help me, please ask. If you think my objectives will not be served within my budget, do say so, and suggest alternatives you feel sure of which I could then save for. If there’re some sound principles/abstractions that can help me rephrase/verbalise my objectives better, do state.
