shibuchristy
Anyone have any idea about SL 26 and SL 2000...which one is better??
Please make sure it's 50 htz and not 60.Thank you very much .. both are 100v turntable..so how much would value ?approx... without cartridge...
have to check again.. thanksPlease make sure it's 50 htz and not 60.
Japan uses both 50 hz and 60 hz frequency and so most of their TTs are wired for both frequency.
Check at the rear of the TT. It should say 110 volt 50/60 hz. If it is so then you are good to go.
SL 2000 uses an 630 ic for speed control. Make sure the TT is maintaining speed by testing on 33 and 45 rpm records. If there are instabilities then you would have to make sure that the IC is within specs. If the speed instability is due to dirty switches, it can be set right. If the ic has drifted then DO NOT buy as the ic is no longer available unless you get the psb of some other technics TT which uses the same ic and use it as a donor.
Hi Mahesh,My present vintage TT has a small xformer to convert 110v to 220V and it hums.
So if you say it's a non issue that's not correct IMO
Yes.... couldn't find any online . So seems I have to find a transformer maker and make a Stepdown..Hi Mahesh,
I have had 3 TTs, imported from US (110V), Mcro Seiki, Technics, Pioneer etc and and none had any issue with voltage converter. I also has a vintage Kenwood tuner imported from US. I am using cheap MX voltage converter without any issue. The hum could be from something else.
@shibuchristy 110V converter are readily available, but 100V are not common. you may need to get it done from transformer manufacturer.
Sachin
There could many causes like grounding, transformer picking noise, bad RCA cables, bad tonearm cables etc.Hi sachu
What else hums in a turntable ?
Just for my info..
