After running helter skelter auditioning as many speakers as I could, I found I had a thing for PSB / NAD combo.I liked the sound so much that I do not want to search any further. (apart from 2 ribbons)
However, this raises a few basic doubts which I would appreciate if someone could clear for me
1. Is it the speaker or the AMP
I have been auditioning all this while using Yamaha sound and none of the speakers I saw was a perfect match until now. Now that I liked something with NAD, I'm doubting if it's due to the speakers or the AMP?
I do intend to go down and test with another AMP, but wanted to know the opinion of the gurus on this.
2. Which other amps give the same NAD sound
The sound I heard was smooth, a bit dark (as if vacuum existed in between instrument sounds), VERY musical and no excessive treble with lots of good punchy bass.
I was seeing a lot of negative comments about NAD about QC issues, being china made etc.
Given the above fact, I wanted to know which other AMP gives the same sound and power as NAD (375BEE), but is much better made? (problem free / excellent construction).
3. Do we really have to go to all this pain to find the matching sound - why not ...gasp use the EQ?
The moment we start talking about the type of sound an AMP/speaker produces, its a given that we are not listening to THE original sound.
So why not use the EQ to say reduce the treble or increase the base?
Are there any pro EQ's to be had that can reduce only a few certain frequencies instead of modifying the sound as a whole?
Do good amps have good EQ's ?
Arun
Arun
