superczar
- Joined
- Feb 5, 2008
- Messages
- 831
- Points
- 93
All my life, I have been an instant gratification fan.
For a change (and for a combination of reasons), I now have 1 long year to plan and design dedicated HT room in a house extension and perhaps another 6-12 months to bring it to conclusion
Objective: Build a best bang-for-the-buck dedicated HT setup. Projection based, darkened room, meant solely for HT
Area: The section of the house is up for a redesign in some time so I have some flexibility in terms of setting aside the size/layout etc. A 15X10 feet is the base I have to work with .
Budget - Value oriented - In the sense if I was lucky enough to snag a just a DIRAC pre-processor for 1L , I'll gladly pay for it and pick discrete amps separately.
At the same time, I won't shell much more than that for a regular Audyssey AVR. Same sentiment goes for speakers and projector . Open to buying and stocking pre-owned for the right equipment at the right price
Video: Projector based. 4K preferred, 1080p is OK if I can get something which is really good with good HDR
Screen: 100" motorized
Video source: Apple TV in all likelihood as I like the OS and the ecosystem
Amp and Pre Amp/ Processor: Open to discretes if I can find something good else a Denon or Marantz AVR with Audyssey XT32 will do (e.g a SR6013). Audyssey XT32 is the minimum baseline
Speakers - Preferably in-wall else on-wall. While it may not make sense to use regular floorstanders etc, I also know that demand for good in-wall speakers is really low. If the in-wall option is overpriced, open to standalone speakers too. Would also need a sub that's adequate for a 150-200 sqft layoutbut not too fussy about the choice
Other considerations:
Completely open to all recommendations/suggestions !
- Seating - 2 rows of 2 recliners (2x2), maybe 2X3
- Dampening - Definitely need sound dampening, open to DIY
- Lighting - Theatre style lighting, Will go with LIFX or Hue integrated with home automation in all likelihood unless better choices are out there
