Subcenter2009
Dear friends,
I initially posted this on a fellow FM Manish's page just now but, I think this info is important. So, I'm starting a new page. Hope this information is useful.
Try this method of connecting your Home Theater:
Connect BluRay/DVD player to TV via HDMI.
Connect HD ready Set Top Box to TV via HDMI.
Connect BluRay/ DVD player directly to AVR via Toslink/Co-axial.
Connect TV to AVR via Toslink/Co-axial.
Results:
If earlier facing video issues, not any more. Video should work fine now.
You need to switch on AVR only when using Home theater.. For normal viewing, TV speakers will do. While using Home Theater, mute the TV.
The AVR sound will work fine when connected directly to BluRay/DVD player via Toslink/Co-axial.
You should now be able to get full 7.1 surround sound output from the HD DTH set top box and USB jump drive of the LED/LCD/ Plasma TV. The USB pen drive and HD channels will, play as Dolby Digital 7.1 or Dolby ProLogic IIx/z or DTS Neo on my Yamaha AVR. Only DTS output encoded from the Pen drive is doubtful.. But that does not matter since, all HD/SD channels and most downloads are either in stereo or in Dolby Digital (AC-3). No problem since you are using Toslink/Co-axial between the DVD player/TV and the AVR. Newer TVs support everything.. So, get a TV with USB port and most importantly, A Toslink(Optical) / Coaxial audio port.
Hope this helps,
Yours,
Subcenter2009
Results:
Hope this helps,
Yours,
Subcenter2009
