Tower speaker placement 2 feet above ground ?? Inputs needex
Guntur
I am shifting to new house , in which there is
Place for tower speakers placement beside my 32 inch led.
Is it advisable to place tower speakers above ground level ?
The goal is to have your tweeters at ear level in your normal listening position.
I have my Z5 about 9" off the ground. I like the sound that way. 2 feet does seem extreme I must say.
your problem will be getting your supports exactly the same height and level. I was OCD and told the carpenter about my need for accuracy and precision in his measurements. Not that he gave a **ap :)
ciao
gr
It might be a good idea to give more details why do you need to do that. Might be a way around.
Mine are about 200 mm on a metal frame which allows sound movement? and also away from the wall about 450 mm . I think it's worth moving them around to see what gives you your optimal performance to suit your room
Sent from my Pixel XL using Tapatalk
I have my towers a foot off the floor with custom designed sand filled stand. The towers get locked inside the stand to minimize any kind of resonance.
This suits my near field listening.
