Wanted Turntable headshell wires (only wires)
Wharfedale Diamond 11.1 & 11.2 Speakers
paras0710
New Delhi
i want wires to connect cartridge to headshell .
BUYING, SELLING or TRADING indicates your automatic and mandatory acceptance of HiFiVISION.COM Trading Rules and Guidelines!
Do not blindly trust every seller or buyer! Protect yourself by following the below safe trading tips.
Safety Tips
For Buyers
  1. Always meet the seller at a safe location and inspect the item before purchasing. Following this one rule will help you avoid most scams.
  2. Watch out for unrealistic offers. If it appears too good to be true, it probably is. Unrealistic offers are used to motivate purchasers to make hasty decisions.
  3. Always verify the seller's credentials. Ask the seller to provide a photo ID and proof of address.
  4. Ensure that the product you are buying is not stolen or fake. Always ask for a purchase invoice.
  5. The best way to transact is to collect the item and pay at the same time. Never transfer funds or use a debit/credit/atm card to pay someone you do not know before collecting an item.
  6. Ask for clear information on condition of the item, price, payment and delivery method.
  7. Use only those payment methods that you trust and are familiar with. Never give out your financial information.
  8. It is recommended to purchase items directly from the seller.
  9. Always test the functioning of the item before purchase.
  10. Do your research on comparative prices for the product.
For Sellers
  1. Try to take the full payment at the time of the delivery. Remember to use a safe location to meet.
  2. Watch out for fake currency and money orders. Be aware that banks will not honour fake currency/money order and will hold you responsible for it.
  3. Verify the buyer’s credentials if necessary.
  4. Ensure that your product meets the features you list in your ad to avoid any misunderstanding with the buyer.
  5. It is your responsibility to prove that the product you are selling is genuine and not stolen by providing the necessary proof of purchase.
  6. Do not share your financial information except the one required for payment.
paras0710
New Delhi
This what I am planning to use if cannot found actuall wire connector set.
jls001
paras0710, excellent idea. But that should be a very high quality wire. Thanks.
Yes, excellent idea!
Of course the wires have to be solid core for such winding to hold. Reminds me of how telephone wires used to be wound like that on old telephone tag blocks:) before knife edge Krone tag blocks took over.
paras0710
New Delhi
Better solution is to use the pins from a DB9 type female connector -
9 Pin D Type connector Female [Serial DB9 F] - Price-Rs.7.00 : Ventor-India, Online Electronic component Shop
And litz wire. In the worst case, a cheap headphone cable can
serve as a donor for suitable wire -
Litz Wire - Manufacturers, Suppliers & Exporters
Make your own plug-in
I tried that connector you are talking about and found it is no? useful as not all connector are of same quality and you cannot guess the quality of pins inside. The one I used looks exactly same as the link provided by you.
jls001
BTW, I have used sockets removed from DB9 data connector. The socket hole is smaller than required for cartridge pins, so it needs to be carefully pried open to make the hole bigger. Further, the depth of the socket is less than the length of the cartridge pin. And the two halves of the socket must be carefully bent to grip the cartridge pins, and tightly clamped when connecting. It is possible to make it work quite well, but it can be fiddly to fit it securely.
But please try it as it is cheap to get a DB9 connector and cut it up to harvest the socket. May be you'll find a better way of making it:)
And I can vouch from experience that old headphone wires work very well for tonearm internal wiring. It will work here too.
quad
Hyderabad
You can look for other, more suitable, connectors to scavenge the pins from.
Perhaps this kind of female XLR connector ?
