Understanding DACs and the process of digital to analog conversion
asliarun
Chicago
In an attempt to better understand DAC devices and even the overall process of digital to analog music conversion, I came across a couple of excellent articles. So I thought I would share with the forum, and hopefully gain/exchange some views and observations from forum members.
PCM explained
Mother of Tone - The CD Format
R2R conversion
Mother of Tone - Conversion Techniques
(Such a good explanation!)
24bit vs 16bit, the myth exploded!
(What a nicely written article!)
The R2R sound and PCM1704 (versus the most popular Delta-Sigma DACs)
dac
(Huge article - needs a ton of patience!)
Note: I really need to read and re-read these articles properly to develop a meaningful understanding of DACs. I thought we could at least initiate a conversation on this subject to make this a little less "dry" so this doesn't feel like homework.
On an interesting note, Audio GD (a company i quite like) makes 2 models of DACs with PCM1704. The Master 7 ($2200) and Reference 10.32 ($1850). To my (limited) knowledge, this is the only option in this (low) price range, barring some no-name Chinese options that can be found on ebay.
Thanks for sharing this. Mother of tone is a nice website and was good to read this again
R2R is the holy grail. Two of the most revered chips - pcm1704 and tda1543 were r2r. Unfortunately this means that anything well implemented with those chips that offers bit perfect I/o and minimum phase filtering are very very expensive and hard to find.
The TDA1543 dac I bought was $40. Of course it needed an external power supply, which I am not sure my switching adapter is the best to deliver, and it ran up close to my friends $2000 dac, so close in fact that he was in tears nearly cos the $2000 dac barely sounded any better on his $15000 B&W's.
So why you guys say TDA1543 stuff is expensive ? I guess you could get better build, paralleled X 8 and on board power, but still I would think a few 100 would do it.
Cool.
Srinath.
Peter Daniel (DIY Chip Amplifier Kits, PCB's, Components and Information.) makes a minimalistic DAC based on TDA1543 with very high component quality such as Black Gate caps (and he then practically gives away for almost cost price). I am in the process of buying his DAC. He used to sell it as a kit but now sells it fully assembled as a board (without case) or with case. Here are a few reviews:
Audiosector USB DAC -- my new DAC--(and comparison)
Here is the 6moons review: 6moons audio reviews: Audio Zone System
You are preaching to the choir. I used to own the fully upgraded audio sector DAC hand assembled by Peter himself. I now use an AMR which IMHO is the best nos implementation this side of the top end zandens.
The audio sector DAC is fantastic for the price - has excellent tone. Only real downer is slightly loose bass but that's OK for the price.
Wow, really nice to know that you have used and liked this DAC. And your recommendation means a lot.
While researching this DAC, I also came across Audial - which makes a DAC based on the same chip and has similar minimalistic design philosophy.
Here is my story with a bit of background.
I am totally biased for tubes. No pun intended.
Tubes in a well designed and made dac will knock the living daylights out of anything.
Unfortunately, I dont have the moola to get one of those.
So I got the crappiest TDA1543 I could find ~2 years ago. $36 shipped. Came with a dc adapter that weighed all of 10 grams. The shock of my life was when my friend with a $2000 ESS dac called me in tears, this is 99% of the ESS dac.
I would try a 4 chip TDA 1543 @ $40 shipped. But that's just me. I have tubes in a lot of other equipment, pre's and power amps, and I may not need more tubes. If you only have 1 tube equipment - you may want a DAC, or heck with it, I actually like Tube pre amps the best. They last loooooooong time, are pretty trouble free and run in front of an accurate amp, sound just like there is a tube amp in the room ,with the added benifit of being more powerful. I ran the carver M1.0 t and dynaco PAS and people thought I had a 100 watt tube amp.
Cool.
Srinath.
Nice dac albeit a tad overpriced for a very simple design. Also it appears that there is no option to have both async usb and coax input together. For a wee bit more than that, one can get a loaded to the gills AMR.
