Well its perfectly fine to use inverters ,but the low end ones which output square wave can cause long term harm to devices based on inductive load in this case the power supply of tvs be it lcd/led or plasma.
A SMPS is still a inductive load.
I have talked to some senior engineers at Schneider electric ,the people that make APC products for indian market,they did say a square wave does have a effect on the components,while one may not see the effects immediately in the long term it does have some effect.
You also hear buzzing sound in square wave based UPS on corsair SMPS,but not with a sinewave based UPS,so they do have some form of effect.
Fans ,CFL bulbs etc run a slightly warmer with square wave.
Apc does make Sinewave home inverters/UPSYes, as we have already discussed, a Sine Wave UPS is BEST. However, talking of SE/APC, I am not aware of any Home/PC Sine Wave UPS/Inverter they manufacture in India! So its strange that they say Square waves can harm equipment (which technically they are right), they hardly manufacture any Sine or evey Pseudo Sine (Ramp) wave inverters.
This statement may not be correct. Can you please explain why you think SMPS load is inductive ?[/COLOR]
For the benefit of all , could you be specific here, as to what these long term effects are ? I understand this for an inductive load like a fan or a motor, but this is not applicable to SMPS power supplies. As a matter of fact, in an SMPS, other than the bridge rectifier, none of the other components get to see a sine wave . Its all high frequency square waves inside ( ok, not exactly square but with varying pulse widths )[/COLOR]
True for fans because of high frequency harmonics present in square wave. But should not have an effect on CFL because CFL again use a bridge rectifier at the input stage. If you are referring to an old style 4ft tube light with inductor ballast (choke ), the choke might over heat. But if it is an electronic ballast , then it should not have an effect.[/COLOR]
This looks very recent development as about 2 to 3 years old, I didn't see any sinewave UPS. My 1kVA SmartUPS is also SQUARE WAVE.Apc does make Sinewave home inverters/UPS
APC Home UPS, 1000VA, Sine wave output
APC Home UPS, 650VA, Sine wave output
APC Home UPS, 850VA, Sine wave output
Even before the above models they had made a 800VA sine wave model.
They also have a lot of sinewave based UPS meant for PCs and all the way upto data centers
My apologies buddy, I have a 1kVA "Back-UPS"If you mean you have a APC Smart UPS its has to be a Sinewave.I have a 1kva model its a sinewave.
There was a sinewave inverter by APC even in 2004 called BI800 F orT APC Power Inverter 800VA with Tubular Battery
APC Launches Pure Sine Wave 800 VA Inverter - UTV Channel Times
This model was replaced in 2006 by the squarewave models
In 2007 APC sine wave inverter made its return with the BI1000I
In 2010 two more models APC 850sine and 650sine were launched.
We can use Square wave inverters on any SMPS based power supplies without any issue. This includes all LCD/LED TVs/Monitors and even Plasma TVs.
CRT Monitors and TVs will have humming noise and may develop temporary or permanent issues as their power supplies are not SMPS based.
