kishanvkumar
Folks,
Need some advice here. I already have a D2H HD connection for last one year (Black set top box). No problem with that, but with my distance and 46" inch LED, the SD channels are more like horrible to watch. HD channels are good. Just was thinking, is it worth buying the new HD DVR from Videocon? Will picture quality change on this upgrade? SD channels any better, Also the remote responsiveness is painfully slow. Will that improve on the new STB? or the upgrade will only give me the recording feature and 1TB space ? The software/Hardware is same as the normal HD box?
Just wanted to ask before plunging around 7000/- on it.
